Can you switch from a cloth surround to foam?
I'll try to get the 20mm foam surround, and then I'll update you with the results, or should I try getting the rubber one (h=18mm)? Is foam really softer than rubber and is it worth to compromise on durability?
The foam surround should last 10 years for sure. A rubber may last longer, but change it's hardness. High performance speaker do not live for ever like a cheap all paper cone in a vintage radio receiver.
Buy a ferrite ring magnet and stick it to the back of the magnet structure.
Opposing force north north or south south will lower Qts attracting force will up Qts.
In a German speaker diy magazine they made a speaker with the Visaton BG20 and by
attaching an additional ferrite Ring magnet on the back pole plate Qts was lowered from 0,45 to 0,37
Reactions: GM
