bought a couple of caps off the bay they are supposed to be wet tants but they have no + markings and both end caps are red non polarised ??
bought them for the feedback of a hacker nap can anyone confirm these will be ok to use .
i'm out of idea
what if you measure the continuity between the lead w/ the metal body?..but nou need to scratch the plastic insulation first.just a little scratch to let the probe touch the body 🙂
bought them for the feedback of a hacker nap can anyone confirm these will be ok to use .[/IMG]
Hi Glenn,
If there is no + marking on this tantalum capacitor it is probably a military grade wet slug tantalum capacitor non-polar eteched foil type.
Hope this helps.
thanks tommy any good for feedback ?
Difficult to answer. You need to try to see if you like the result in your application. There is a thread about it here:
http://www.diyaudio.com/forums/parts/56015-tantalum-capacitors-signal-path.html
just put them in with some 10uf smr film caps on the input sounds good and can only get better 😀
if it does not violate the rules would add tis link
these capacitors seem very similar
ebay : 2pcs U.K STC / ITT 100uF 40V Acura Military Silver Wet Tantalum Capacitor CA51
yes.it's the same
and according to the ebay pic, there's + markings on the left of letters..so the orientation is left to right for input/output caps..
i have a mundorf bp and one of the leg was welded into the metal case
but if there's no "+" or any sign about the polarity, it should be np/bp 🙂
N.p. type by back to back connection (also electrolytics)
I think maybe suffering from progressive degradation
- Design & Build
- Parts
- can you identify this capacitor ...????
