I came across this power adapter...
http://www.goldmine-elec-products.com/prodinfo.asp?number=G15566
14 VAC @ 1220 ma for $2.
I was wondering if you could hook the single output to 2 recitifers to get + and - rails at 610mA. Will that work?
If so, it's a pretty interesting option for a power supply for op-amp circuits.
u mean voltage doubler?
yes ,ii will work .
but the output voltage will be half wave rectified ,soits not that "clean"
to drive an op amp (if its amplifiying audio signals) u'll need to use some heavy filtering ...🙂
yes ,ii will work .
I wasn't really thinking about half wave. I was thinking of two full-wave rectified signals with each getting half of the current.
I guess there's one way to find out...
There is a way, half wave using 2 diodes. If current is not high, you won't get problems in getting a clean output with reasonable capacitance.
- Use one of the outputs as GND
- Connect the other output to the anode of one diode (its cathode is the positive output) and to the cathode of the other diode (its anode is the negative output).
- Connect at least 1000uF capacitor in parallel with each output, to GND.
This worked for me in a switching power supply, at 80KHz but the principle is just the same, but you need more filtering.
Hi Pierre,
that sounds like two half wave rectifiers in parallel.
Am I reading your response correctly?
Dual polarity supplies from one secondary winding! Seems the only downside is high ripple.
What DC rails are you after?
Rectification of 14VAC (whichever way you do it) gives you 19.75V DC minus the volt drop of the recitifier. Rectifiers typically drop 1.1V to 1.5V. You want complimentary rails so I'd sugest a virtual earth circuit (google it for more detail).
A good virtual earth is basically a resistor divider pair in series across the supply (giving you half of your DC supply at the mid point) feeding a non-inverting unity gain opamp (to handle current through the virtual earth).
Sam.
Sam.
samborambo said:What DC rails are you after?
Sam.
Good in theory, but only works when the supply loads are reasonably balanced; any difference greater than the op-amp Iout(max) causing the rails to shift.
But I know you knew that 😉
sss said:u mean voltage doubler?
yes ,ii will work .
good rejection linear regulator/amplifier to drop each side to 12V. Add a series current source/limiters, and you have a great balanced PS for Op-amps.🙂
- Power Supplies
- Can you drive two rails from one transformer output?
