Can you bridge an AMP3 kit from 41Hz ?
you could parallel inputs and outputs, but that doesn't give you any more oompf, except if you want to run at a lower impedance, you could for example parallel four 8 ohm drivers and run the amp comfortably at 2 ohm, with the benefit of 12dB.
