From the data sheet, it said that when "register 3" is "1010", the sample frequency is "fs", and output is "CD-ROM(I2S-bus).
Does this mean it can output non-oversampled I2S signal which I can then feed directly into TDA1543?
http://www.semiconductors.philips.com/acrobat/datasheets/SAA7327_2.pdf
pop11 said:From the data sheet, it said that when "register 3" is "1010", the sample frequency is "fs", and output is "CD-ROM(I2S-bus).
Yes, but you would need to reprogram the chip his interface.
I had once the idea to reprogram the philips cd713/cd723 (saa73xx), with a a pic microcontroller. It would be quite simple and cheap, read the data from original interface and output manipulated data. This way you can keep the original controls and (display) features.
Anne.
