i know this diagram is crap but any way, if you cant see it properley i want to connect 2 amps to one sub,
cd player into 1st amp through the RCA in
using the RCA out from the 1st amp, connect to the second amp
through the RCA in.
then bridge the sub to the second amp
can i do this
through the RCA in.
can i do this
You can do that, and it'll work.. there's just no point. You're not going to get any extra power by running the rca out from one amp to the rca in of another amp. You're just passing the line level signal through the first amp onto the second. If you want to run two amps on one sub, you need a DVC subwoofer.. And you need to match the gains on the amps.
