The only difference i see between these two drivers are as follows:
Thougth, the Qms remains the same for both drivers (5.1). Frequency response seems the same.
Looks like the only difference is in the magnet system. I wonder what would happen if i'll remove the shielding magnet off the 18S driver? Would it become 18W?
I already have a pair of non-shilded 18W, and want to use two midbasses per speaker so i'd like to modify the 18S to make it become 18W.
Thanks!
Code:
18W 18S
BL 6.8 6.4
Qes 0.39 0.44
Qts 0.36 0.4
Thanks!
If nobody else wants to answer this ; I'll give you my opinion.
if this is for a sealed box 2.5 way and one of these drivers is going to use a first order cut down as low as practicable, the do your box calculations and use the appropriate box size for each driver, and I would use the woofer with the higher "Q" as the low boost woofer.
I have no idea if you want to use a ported box
The individual values are not as important as the ratios Fs/Qts and Vas x Fs² and if they are close then it's fine. You usually find more variation (10% or so) in manufacturing tolerances of driver to driver.
Model both in the same size box and tuning and you will find they wouldn't vary more than about 0.5dB-1dB. Don't go by the optimum calculated size for both as that could vary significantly. You are interested in their performance in the same conditions.... volume and tuning.
If they are for a 2.5 way, then use the 18S as the 0.5 woofer. For an MTM you are better off with the same drivers but I doubt you would hear a difference unless you had golden ears.
Don't try and remove the shielding and no it wouldn't make it a 18W.
How would one remove the shielding off of a 15S?
I read recently how some one removed the shielding off of a 18S, but I can't find the thread now.
I have 26 spare neodymium magnets I want to symmetrically place on the back of each driver, around the vent that comes out the back. Is this a bad idea, lol 😀
I have a 15S/8530K01, I want to use as a midrange, so I want to make the BL a little higher so it might approach the BL/performance 15W/8530K00 model.
I been thinking and I have come to the conclusion that this is a really bad idea due to the nature of magnetic fields. Can't believe I overlooked it earlier.
