Can I use a PP interstage for SE?
If the IT has a small natural gap that's good because it can cope with some grid current in the output stage.
I would use an input phase splitter ( active or step-up transformer if the preamp can drive 600R) and then a "modest" triode strapped 6V6 PP stage to drive the transformer. The current production and vintage Russian 6V6's can surely take up to 420V plate voltage. Despite 3:1 overall step down it can still provide some 200V peak-to-peak in class A with very low distortion without using high supply voltage or accepting other compromises.
Ah, right.
OP, do you have your mind set on a specific topology or are you just weighing your options?
Sure I am weighing my options. I would like to do pure SE throughout - because I like things to be simple as possible.
I am thinking of input tubes (basically what I have):
  • 6h6 (6h30's all died)
  • d3a
  • 6n1p
  • 6sn7
  • 6sl7
  • ecc88
  • ecc81
  • ecc83
Output tubes:
  • el84 or russian equivalent
  • Maybe an alternative but I would need to buy those, so prefer el84
Part of the reason why I stopped the Hypex trouble shooting is that I do not need the watts (PHY-HP 8 inch drivers). I guess only some watts will do.
Also the drivers are supported by 2 active subwoofers ~ to about 80hz.
  • d3a
  • 6n1p
  • 6sn7
  • 6sl7
  • ecc88
  • ecc81
  • ecc83
Output tubes:
By considering Parafeed you have already moved away from as simple as possible.
Shoog
  • d3a
  • 6n1p
  • 6sn7
  • 6sl7
  • ecc88
  • ecc81
  • ecc83
Output tubes:
ECC83 and 6SL7 are surely ruled out unless you use more complicated stages like hybrid mu-stage with para-feed. The low plate resistance types (less than 2K) are those that will work best being the transformer made to work with 6H30.
PP class A driver stage is really the simpler option. If the power tubes are 2xEL84's in parallel for 8-9W you can use Schade feedback (plate to grid) with 6N6 or 6H30 as class A PP driver. No high voltage power supply and simpler audio circuit.
Not too many options if you want to keep it as simple as possible.....
