It is my understanding that a. a digital signal is expected to/from a (mini) USB connection and b. that while the PAM8403 output is regarded as digital it is actually a PWM signal. If this is so can I feed a USB port - perhaps to be connected to an iPhone - from a PAM8403? (I have attached the PAM8403 spec sheet.)
i want to provide output to an iPhone. the source is music which has been manipulated to emphasize certain components.
it is an analog signal. (I have a few PAM8403 modules around and was hoping to use one.)
Is there a way i can feed a mini USB jack so it would be palatable to an iPhone?
Still not sure I'm understanding your goal. Are you trying to send a line level analog signal to an iPhone? If that's the case, you need to use a USB audio device with an ADC.
No, but I now think I may have gotten it all wrong.
What level input does an iPhone take? If it's line level then i'm set. if it's speaker then i just have to branch off of the output module's input.
but if it's mic level then????? what do you suggest?
Won't work. The mic input from a 3.5mm adapter has audio filtering meant for voice. It's not a general purpose audio input and it's also mono.
https://en.m.wikipedia.org/wiki/Lightning_(connector)
There you See the Apple lightning connector pinout. There seems to be no Audio input possible.
Just buy something like a Behringer UCA222. It's relatively cheap and you don't risk frying your phone.
- Class D
- Can I Send PAM8403 Output to a USB Jack
