Can I break-in the speakers right out of the box?
Hi!
I just received a pair of Mark Audio Alpair 10.3.
I took them out of the box, placed them just on the table and plugged them into an amplifier to check if the drivers were working.
I've been listening to some vocal/jazz music for 2 hours or so at low volumes. No bass at all, and sometimes the sound is a little bit dirty... but I guess that's becuase they're not in a box 😛
The question is; can I do the break-in of the speakers like this?
Or should I always put the speaker in a box?
Thank you!
Just remember that you have no air spring to dampen movement at low frequency, so make sure you respect the xmax limits. Low volume should be fine.
And, yes, that does assume break in is actually important, which is questionable for a full range driver.
