Hello. I want to use ltspice to find how much noise I have with an ecc83 tube. Noise varies with voltage applied and current, I need to know if I can accurately model current noise from a tube in ltspice ?
Thank you.
Thank you.
You can if you have a model that accurately accounts for noise. As far as I know, the available models do not take noise into account. You can add noise to the model if you have experimental data on noise.
