can anyone offer help understanding the flow of this circuit
A "Pro" repairing such an amp would not start without a signal generator and an osciloscope.
This is the "proper" way. Anyway, this amp and this fault are so simple a voltmeter should do.
An osciloscope is like a voltmeter on speed, but not needed if the full rail voltage is at the output.
It is like searching for an elephant in your living room. You can't miss it.
An osciloscope is like a voltmeter on speed, but no needed if the full rail voltage is at the output.
First problem I am getting 90vdc to the positive and negative rails
Do not run the amp for further testing of the driver stage until the voltage problem is fixed.
Have you thought about selling just the Mosfet's at eBay? They are very rare and should net 3 times more than this amp is worth?
Just an idea. To be honest, these amps are not the best sounding ones in the world any more. They are very sensitive to different speakers. With some you just don't want to hear them, with others, for example some horn combination, they are just fine. I still use them, but only on some sub woofer.
There are a lot of very low priced D-amps that can do better, reliable, from sub to top. Sorry to say this... as I still have some of these old iron lumps, compareable to the Hafler amps.
