Ok... I'm doing some repairs and I'm having trouble finding a data sheet for this IC and thought maybe someone here might have seen this before. It appears to be distributing a clock signal of ~11.2896MHz to four AK4524 Audio codecs... Here's a pic.
The markings as far as I can tell are as follows:
MK70-1
231120A
0240CA
If I have the orientation correct then the output on pin 6 is going through the 33ohm resistor and then to the four AK4524 codecs...
I've tried Google and distributor/manufacturer websites, but came up empty. Does anyone have any idea what this is and what the pin out is?
MK70-1
231120A
0240CA
11 years later... literally.
Found it or something close (11 years later). Found this by chance looking through a list of obsolete parts. In case anyone else was looking here is the data sheet and part number of a chip that matches in footprint, pinout and usage.
MK2302-1
https://www.idt.com/us/en/document/dst/mk2302-01-datasheet
What is it?
Multiplier and zero delay buffer. Clock goes in and gets multiplied and the rising and falling edges of input and output are synchronized making a perfect multiplication of the input signal. ICLK * 4 is the configuration in the photo which is from the main board of the ST Audio ADC&DAC 2000 box. Originally I was reverse engineering it to make a windows driver but the PCI card was stolen along with that old PC. Now I'll be converting that box to USB with a 44-pin adapter. Just waiting for this USBstreamer thing to come in the mail. Have other things to do but maybe I'll make a post on it someday with photos. 😉
MK2302-1
What is it?
