I am building a clone of boenicki w5 with these driver:-
Tang band w5
Founteek FE85
Dayton TD20F
Can anyone help me with the crossover schematic for this setup. Please 🥺. I am attaching few schematic of which i found online with different tweeters.
Tang band w5
Founteek FE85
Dayton TD20F
You need a choke in series with the Woofer otherwise it will unbalance the system because it is wired full range.
Brother i am replicating boenicki w5 configuration. Can you help bcuz i am using Dayton TD20F 4 ohm instead tang band tweeters
If anyone has 3d file of the model and Xover designs for boenicke w5 than please help me out.
@RomanMarts plzzz initiate a converstaion
It really doesn’t matter. The Boenicke isn’t a wonder of linearity anyway, just throw another tweeter in. You won’t notice the difference I guess.Brother i am replicating boenicki w5 configuration. Can you help bcuz i am using Dayton TD20F 4 ohm instead tang band tweeters
