Can a portable CD player be considered as a balanced source?
Hi
If you record a CD with the hot (in phase) signal on the left channel, and the cold (out of phase) signal on the right, then I think the CDP could be used as a balanced source. Must be worth a try!
Hope this helps,
Tim
"Of course to make your recording he'd need a balanced source to begin with, or a very good phase splitter."
I had in mind using the "invert" function in an audio editing package, like Cool Edit.
Let us know how you get on Bricolo.
no
I was thinking about using a classical portable cd player, and a classical cd
then: on a amp with xlr inputs:
leave ground unconnected
use +in with the cd player's output (left or right)
use -in with the cd player's "ground"
and the same for the other channel
