Can a fixed and variable LPF be used at the same time?
The amp i'm looking to get has a 12db variable xover on it. To get a sharper rolloff could I also use a 80hz 12db LPF? I only ask because I have one laying around from parts express. Would there be adverse effects? Or would they simply work together as I suspect? Thanks guys!!
The signal will be attenuated first by the variable x-over so I guess he won't lose too much in power and heat.
If you use the variable x-over below 80 Hz or at 80 Hz, I'm quite sure you can use both. Check if the x-over can take some power and heat.
