I am able to use the analogue outputs on the UMC1820 with camilladsp (on linux), but nothing seems to get through on either the electrical spdif or the optical toslink. Using an alsa loopback works fine to get audio to the UMC1820, but I really want to drive camilladsp with input from another computer, not the one running camilladsp.
The number of channels for analogue output also seems to vary, having worked with 8 channels, 10 channels and even 12 channels . Can't remember what the circumstances were at the time.
My current conclusion on this issue is that UMC1820 simply does not work properly with camilladsp / linux. Prior to this, I was using brutefir, mainly with other cards, but also with the UMC1820 - it fairs no better.
If someone could show me a config.yaml that will work to access the UMC1820 I would be very grateful. I have wasted literally weeks on trial and error tests.
None of these issues are helped by the complete lack of any detailed tutorials or instructions concerning any linux software. The instructions, such as they are, are always incomplete and seem to assume you are an expert in everything that the instructions do not cover.
Many thanks,
Many thanks,
Looking at the back panel, it says that spdif input is number 9 & 10. That would be 8 & 9 in camilladsp since it starts numbering from zero. Did you try capturing from those channels?
This device has adat, and that usually means that the total number of channels depends on sample rate. You can use aplay and arecord to help figuring out what to use, see the readme here: https://github.com/HEnquist/camilla...md#find-valid-playback-and-capture-parameters
According to the manual and my experiences using these interfaces, the UMC1820 can be put into two different modes and this changes what happens with the optical (TOSLINK) and coax SPDIF inputs and outputs on the rear panel. The two modes are:
1. SPDIF MODE: there are 10 analog output channels plus 2 SPDIF outputs (channels 11 and 12) via both the TOSLINK and coax connector. Coax SPDIF input is disabled.
2. ADAT MODE: there are 10 analog output channels plus up to 8 ADAT channels via the optical connectors (at 44.1 and 48kHz). In this mode only the coax SPDIF output (and inputs) function. Channel assignments for these depend on sample rate.
These two modes are switched on the front panel, not from the software/driver side. See the manual for more info.
See page 12, item 13 of the user guide for info on how to switch modes and for details on the sample rate dependencies that I mentioned above. Changing modes is done using the small button labeled "OPT I/O" just below the phones level knob on the front panel. DO NOT change the setting while the unit is in opration - it reboots and this may include one or more loud pops on the outputs.
I use the 1820 and it works great, including optical and coax digital input.
Not at the same time though, both are input 8 and 9 like Hendrik says and you switch between them with a physical switch like Charlie says. Don't have it in front of me but it's near the headphone outputs, and the only button with a lighter grey box behind it.
Thanks for the help. YES - that works fine.
Although I still have many other problems.
1/. I set the sample rate for camilladsp at 96Khz but supplied a 44.1Khz sample rate signal, the result was a mangled signal but still recognizable as the source material. I tried changing the filter files (from rePhase) from 96Khz to 44.1Khz and that fixed that problem, yet I had supplied a "resampler" directive in the camilladsp config file - wondering why this did not seem to work.
CONFIG FILE: (
devices:
samplerate: 96000
resampler:
type: AsyncSinc
profile: Balanced
enable_rate_adjust: true ).
I tried with and without the "enable_rate_adjust: true" but that made no difference. I believe it should not be there. Not sure what you have to do to get reampling to work. The tutorial does not seem to indicate that anything else must be done.
2/. Both my references to (capture and output) the UMC1820 card are in the form of "plughw:UMC1820". If I take out either or both of the "plug" prefixes out and just use "hw:UMC1820" I get a message saying "Capture error: ALSA function "snd_pcm_open" failed with "No such file or directory (2)".
Any help very much appreciated.
CONFIG FILE: (
devices:
samplerate: 96000
resampler:
type: AsyncSinc
profile: Balanced
@maglevrabbit Every audio interface that I am familiar with does not detect (natively at least) the sample rate of an SPDIF input. You have to know that in advance, and then the entire interface must run at that rate. There is no onboard ASRC. That has nothing to do with CamillaDSP, but rather the problem is that the interface thinks the bitstream coming in is at the rate that you set it to (96kHz) when actually it is at another rate. This sort of "wrong" interpretation of a digital audio bitstream cannot be "fixed" by any software later on down the chain, not ALSA and not CDSP.
Just wanted to add... I have faced a similar problem in the past with my own DSP app (GSASysCon), although it is not really app dependent. I use GSASysCon and a computer as a preamp for an audio system. There are analog inputs and digital inputs (CD player and digital radio but I want to run my DSP processing and the output audio interface at 96kHz. To get around this, I bought an additional digital to USB interface to handle the CD and radio at 44.1k Hz. The main audio interface is run at 96kHz for analog inputs and analog outputs. GSASysCon does sample rate conversion when there is a digital source playing. This costs more (I had to buy an additional digital audio interface) but it works great.
How does the UMC behave when fed spdif input at a different rate than the one it expects? For example what is the result of recording with the UMC set to 44.1kHz and feeding it with a 96 kHz spdif signal? And with the opposite, set to 96 kHz and fed with 44.1?
If it handles both cases well, it might be possible to switch the camilladsp config automatically with a little scripting.
- PC Based
- CamillaDSP with Behringer UMC1820 - how to access S/PDIF input!
