In this review, Mike Perrin, who seems to be quite familiar with the DacMagic/IsoMagic says it's phase inverting. Can anyone else comment? http://ecoustics.audioreview.com/ca.../dacs/cambridge-audio/PRD_125471_2738crx.aspx
Shoog said:Opamps are surface mount so not really an option for me to replace.
Shoog
Rats, that's terrible news. I too was hoping just to do an Op Amp swap. Having a four-box CD player (psu, transport, DAC, output stage) is not very appealing.
Sorry to resurrect an old thread, but I am thinking about modding my s700. Are the +15 and -15 supply and 5v digital supplies AC or DC ?
Thank You. I have two QED Positron (15v) regulated power supplies that powered an old modified QED Digit. I propose to use those and the original power supply for the 5v stuff. Would that be o.k ?
Hi Puffin,
The Isomajic requires dule +/-15V for wach channel - not sure whst the QED PSU gives out...
Ok to split supplies, ie 2x QED's and Isomagic for logic supplys (which can be from 8V to 15V).
John
John
John,
How fortunate we are that you contribute to this thread. A couple of questions, please.
1. I have measured over 100mV offset at the dc-output of my Isomagic, does this fall within specification?
2. Were the AD712/711 op-amps substituted with bipolar types (I generally prefer their sound) would any increase in dc-offset be expected due to the latter's higher input bias current?
Many thanks,
Tim.
Many thanks,
Tim.
can anyone describe how to make a frequency multiplier so I can sync the isomagic to a 16.9Mhz Teac cdp
As an alternative to the clock sync, as my teac is the same frequency, could I not take the 16.9Mhz directly from the clock module and send it back to the transport via a 74hcu04?
Jeremy, this is slightly off topic, but I'm unable to email you directly due to being a new member.
I require a similar clock multiplier (2X rather than 3X) but as a novice I have a few dumb questions about the diagram John posted. Hope you don't mind me asking, but if you can spare the time, could you drop me an email. It would be a huge help.
All the best, Tim
All the best, Tim
Can someone please tell me what op amps would be drop-in replacements for the AD711 and AD712's in the IsoMagic? Cost is not a consideration, only performance. Thanks.
audiobomber said:Can someone please tell me what op amps would be drop-in replacements for the AD711 and AD712's in the IsoMagic?
Forget that. Just looking at those surface-mount devices gave me the shakes. I'm leaving well-enough alone.
This is my first post. After reading all threads about Isomagic "magic" I found and bought Iso+Discmagic combo to replace my CD4SE+Dacmagic2i. I am very impressed after just few hours of listening. It is hard to belive my ears. Microscope is good comparision. Or good binoculars. Unbelivable details and focused sources.
After a while I remembered what JohnW wrote on 5th January 2004:
"I know some HARD Hi-Fi enthusiasts - and I mean HARD - I can only spend half a day with them before I need a real swift JD & Coke, they use modified Isomagics (2 boards connected together to make separate L & R units) and have found nothing that betters them - even today"
I am very curious how to do it - connect two Isomagic boards. Any details from forum members? May be Mr John Westlake himself would write some directions?
Regards,
Jarek
I'm new to this forum so first a quick "hello" to everyone.
I'm the proud owner of an Isomagic and Discmagic combo which I am in the process of tweaking in an effort to get the best out of them.
So far I have upgraded the big electrolytic caps with nichicon Fine Golds and most of the small caps inside the Isomagic with Elna Cerafins. I have been really pleased with the results so far and I would now like to upgrade the external power supply for the Isomagic.
I'm quite practical but I have virtually no knowledge of electronics. Would anyone be kind enough to provide me with a circuit diagram and a list of the components they used to build their upgraded PSU? I might just be able to build my own if I have a idiot proof recipe!
Many thanks, Mike
Many thanks, Mike
Well for anyone interested I did eventually manage to build an upgraded PSU for it. The new PSU has separate power supply circuits for the audio left and right channels and another separte circuit for the digital section. The circuits were built on PO5 boards available from Rod Elliot and made up as per the instructions on the Rod Elliot website with LM317/LM319 regulators.
The audio channels are powered by a 25VA 15V toroidal transformer and the digital supply uses the original E core.
I have fitted an IEC type power inlet, a power on LED and and an on/off switch.
The whole thing is housed in a nice alloy case from Maplin with stick on rubber feet and painted stain black to match my Linn amps and Discmagic transport.
This is my first ever DIY build so I'm quite pleased with it.
I have also made some upgrades to my matching Discmagic transport which have made a big difference, details and pics of both available on request.
A very old thread but hopefully someone can supply the info I need.
A long time ago I bought an Isomagic and for whatever reason never used it. Moving house recently it came to light and I need some info - what kind of connector do I need to mate with the co-axial input chassis plug and any suggestions for 75Ohm reasonably priced cable to use.
- Digital Source
- cambridge isodac s700 mods/upgrades
