Hi all. I have a Cambridge 640C V2 CD player that causes a relatively loud thump through the speakers when ejecting a disc that has been playing for a while. It sounds like DC offset so I'm wondering if this might be a static problem although it occur throughout the summer. I'm thinking static because the disc has to be playing for a while. Any suggestions to solve this problem would be appreciated.
Yes, it thumps in both channels. Should I pursue having this repaired? If I do, maybe I'll have the player upgraded/modified also. Are mods to this unit recommended?
Just adding comment here as a matter of interest.
I bought a 340 a few years back and that had the same problem.
I took it back to Richer Sounds where it was exhanged, so I don't know what was wrong with it..
However....
What I can say is that the fault is most likely on the servo board and not the DAC / Audio board, simply because the servo board is a common component to all three models. Audio output is in fact derived from this servo board on the 340 too.
Hope this is of some help.
However....
