calling Moray James, and others ..wav8 or 6BM8 schemtics--PP.
looking for some PP 6BM8 schematics. (Dave it seems that what I thought were SE trannys are in fact PP).
As the wave 8's had received good press, I'd like to emulate them. I have the tubes, the sockets, a 5GR4 based power supply, a phono stage. just want to add a couple of pairs of RCA inputs, a good ground, and an attenuator.
Somewhere I thought Moray had modded sopme pairs of these. Moray are you out there?
frugal-phile™
Joined 2001
I thot i had a Wave 8 map but can't find it.... it is a gain stage>concertina>ouyput stage topology. All of the following bit 1 are the same topology. Hopefully from the lot you'll find an agrreable set of passive parts...
dave
driving?
probably...think I'll bring my wife,a day or two early and "sight see". I may be able to break down Hemp8/OBs , and a t-amp intergrated. If I can get the tube amp done maybe that too...sorry no turntable.... hm,, the replinth travels well...
and for the schems..
frugal-phile™
Joined 2001
Re: driving?
the hemps would be cool... i also have a baffle here with replacable driver module so you could just bring the drivers
dave
you bet...
Nanook: you will need to give ne a little time to dig the schematic up for the Wave 8 they are nice amps. Do you need output transformers? I have a set from a pair of Wave 8's. I had Joseph Lau build me a set of ultra linear transformers for one of the sets I owned (three pair in all). If you need output transformers send me a PM they are yours. Regards Moray James.
http://www.drtube.com/datasheets/6bm8svet1996.pdf
http://www.stevenfenner.com/Music/Univox/Univox_U45B_Schematic.jpg
http://www.tube-town.de/diy/sv-amp/svetlana-amp.html
http://www.lh-electric.4t.com/bin/6W.gif
http://perso.orange.fr/michel.terrier/radiocol/detail2003/philips-h4f74.htm
http://www.bonavolta.ch/hobby/en/audio/ecl82_2.htm
http://www.electra-print.com/el84psapp.php
http://www.diyaudio.com/forums/showthread.php?s=&threadid=57411
http://www.bonavolta.ch/hobby/en/audio/ecl82_3.htm
http://www.mixtel.pwp.blueyonder.co.uk/audio/smallamp.html
Wow...both of you are quick "on the draw" ;)
I have some PP output trannys and the Powwer supply trannys as well. Was planning on a intergrated version of sorts. I am sure the trannys are all Hamond, even though I can't find anything on them (Sparton Radio of Canada reciever is the donor).
apparently a 12M6 amplifier of sorts (RCA under liocence to Sparton).
Thanks both, I gotta get some sleep:)
