Calling all clever people :) What do you make of this?
Lostcause said:
OK guy's, as I said you need to convince me and all the others that ground speed is related to wind/air speed, or at least to the point where it affects this scenario.
Imagine standing by a travelator that is moving towards you...
Now think about the air above it...
Now tell me that the air is being affected other than a bit of a draft caused by the resistance of the surface of the belt...
Now see which direction that draft is going
This can only add to the air speed not cancel it...
Are you preposing that the friction between the travelator and the air will create a significant (or at least noticable) wind?
Do I understand you here?
I'd agree it creates a minute draft, but not enough to influence the experiment.
Lostcause said:
Guy's, you're still over complicating this scenario...
Let's take the 'wheels cant rotate' statement on....
The belt moves in the opposite direction...think about it.....draw two circles, put the direction of rotation on them....bingo! They dont cancel each other out...the belt just becomes the ground under normal take off procedure...not faster not slower...exactly the same.
Yes the belt is ripping right along under the plane. But, for the plane to make any progress relative to its surroundings, it must roll forward faster than the belt rolls backwards. This is not allowed in the given set up.
Draw your two circles and you will see that for one circle to make progress, it must revolve around the other. If one is going around the other, then it must be travelling faster than the other.
Max
eVITAERC said:
Try not to die in shock when you find out that you can indeed pull the paper out fast enough to stop the roll of tape from moving forward, making it just spin in one place.
Quite possibly.
Now add the influence of the external thrust, (the aircraft engine), to the system. Attach a long piece of string with a weight on the end to the centre of the tape, allowing it to pivot freely around the central axis. Chuck the weight out of the window so it pulls the tape forwards. Now however fast you pull the paper out, the roll will still head towards the window at a high rate of speed. It happens. I just tried it.
pinkmouse said:
Quite possibly.
Ah, what you need is a jet engine powered sheet of paper.
Max
Lostcause said:
Ah, an outsider, welcome!
You never know, get browsing the other pages and you may be compelled (or is that propelled) to have a go....
Ah, well since I can't pm you, I'll say here - thanks for the welcome. I'm a computer builder and might poke around this site a bit looking for some tips about heatsinks and other stuff. (I think I am thread-jacking now).
Max
The thing is, lets just say we agree to disagree on this one.
You still have not linked the air the wings are passing through to the ground speed. You cant they are not coupled by anything.
You could have all sorts of wierd things happening to the wheels...it just does not matter...the plane is moving forward as a result of engine propulsion what happens below it is irrelevant.
RDFan said:
t's very relevant - in fact below is moving in the opposite direction at the same speed cancelling any forward movement relative to the earth
No it's not, as eVITAERC's experiment proves. It is totally irrelevant.
It is relevant. The plane moves forward with respect to the belt. The belt (with the plane on it) moves back with respect to the earth. So the plane's movement relative to the earth is nothing.
I don't think eVITAERC's experiment proves anything contrary to what I said. Maybe he can pip in and answer.
RDFan, you need to decouple the plane from the wheels, thay are not the driving force.
The engines move the air above the ground
The engines are strapped to the plane
The wheels are free to move as the breaks are not on
the movement of the wheels is a result of the movement of the plane not the other way round.
Oh, I wish I could post a video...
Try the experiment yourself. It took me about two minutes to build the apparatus, and about 5 minutes on the kitchen table to prove my hypothesis to my satisfaction. I'm sure the results are repeatable. Whatever speed you try and pull the paper away from underneath the wheel, it moves forward.
