Are you seeing pulses of DC approximately the same as the rail voltage on the center legs of the output FETs?
You likely already know but this amp is likely similar to the following:
http://www.bcae1.com/temp/bp1200p1_sm.pdf
not sure if this was the issue, earth was loose. amp is turning on now.
haven't gotten my scope yet to check.
- General Interest
- Car Audio
- Calibra DIGI 1250
