calculatng single fold tapped taper pathlength
Trying to layout a single fold tapped pipe. I figured the fold path length would be the circumference of a circle centered on the baffle end.
My question relates to the position of the end of the baffle. It wont be centered but offset towards the mouth side somewhat.
Whats an easy way to lay this out?
If you use drawing software a recommendation it would be helpful.
