Hi all,
Could someone check this out for me - I think I must be wrong.
I have an amp that uses 4 6L6, 2 6FQ7 and 1 12AT7. All valves are 6.3V and the total current draw for them all is 3.6+1.2+0.6= 5.4A at 6.3V.
Now I want to roughly figure out what current this amp will draw from the mains supply. A quick calculation on ohms law says that that equals 34W. Now I know the B+ and various other bits and pieces will add a bit more, but the plate on the back of this amp says 250W. Fuse fitted is 4A.
Whats the correct way of getting a reasonably close estimate on this?
Fran
Fran
Say you will have 450 V of anode supply voltage and the peakcurrent of 1 tube is 100 mA then you will have 180 watts of peakpower more.
The transformers mostly have an effectivity of 80%, so don't forget then too.
Ah! I knew I was missing something. I am pretty new to this and always have thought of the heaters as the main current draw. Neglecting the low current draw of the B+ - just because its usually in mA. But that was forgetting about the high voltage!
Many thanks,
Fran
Many thanks,
Fran
That 'bit more' you're talking about is the greater part of it! The heaters take only a small proportion of the total consumption, like about 20%.Now I know the B+ and various other bits and pieces will add a bit more, but the plate on the back of this amp says 250W.
