calculate SR in ltspice
Greetings everyone ,, Maybe someone can explain how to calculate SR from this table?
I didn't spot that ltspice already computed for us the slope, aka slew rate. 😳
Here 59.389786V/641.22137ns = slope = 9.26189E7 V/s =92.26189V/us
I don't know how spice computes 97V/us. Perhaps the peak rate is a bit higher that the average shown graphically, but the concept is the same. The graph portrays what you'd see on a scope if you made a physical measurement.
thank you ,,,
sorry I'm still learning to use ltspice,
It's not a matter of LTspice. Its the same when you read a scope. The definition of slew rate is volts per sec (or usec). So if you see a voltage change of 60V during a 641nS time step, that's a slew rate of 60V per 641nS which from basic calculation is 60V/0.641us or 93V/1uS.
Jan
Reactions: Agus sugiono
Saya tidak melihat bahwa ltspice sudah kemudahannya, alias tingkat perubahan tegangan. 😳
Di sini 59.389786V/641.22137ns = kemiringan = 9.26189E7 V/s =92.26189V/us
Saya tidak tahu bagaimana rempah-rempah menghitung 97V/us. Mungkin tingkat puncaknya sedikit lebih tinggi dari rata-rata yang ditampilkan secara grafis, tetapi konsepnya sama. Grafik yang menggambarkan apa yang akan Anda lihat pada ruang lingkup jika Anda melakukan pengukuran fisik.
Jan
Jan
thanks for the enlightenment sir
