Dear All,
How to calculate the exact power delivered in class A in a power amplifier?
Let's say I have one pair of transistors and each of them have a Re of 0,1 Ohm.
I have a voltage drop of 70mV across each Re so I can calculate the current is 0,070/0,1=0,7A
So I have a current draw of 700mA from each transistor. Makes total 1,4A for the pair.
Now I want to know the class A working array into an 8 Ohm load.
The voltage will be
1,4x8= 11,2V
11,2X1,4= 15,60 watt in class A.
Is this correct?
I feel I miss something here... please help me out.
With kind regards,
Bas
The voltage will be
1,4x8= 11,2V
Is this correct?
With kind regards,
Bas
Dear,
In a stereophile review John Atkinson comment on the measurement of the Parasound JC1
"Each of the Halo's 18 flat-pack output devices stands on a 0.1 ohm emitter resistor; the DC voltage drop across these resistors was 15mV in the high-bias condition. As the output is taken from the common point between each pair of complementary transistors, this voltage is equivalent to a standing output-stage bias current of 1.35A, which in turn implies that, into 8 ohms, the JC 1 operates in class-A up to 29W"
I just miss the boat there.
How he get the 29 watts of class A power if the claims the current is 1,35A?
P= 1,35x135x8=14,58watt. That is the halve of 29 watt.
Where I get wrong?
With best regards,
Bas
Where I get wrong?
With best regards,
Bas
Sebastiaan said:Dear All,
The voltage will be
1,4x8= 11,2V
Is this correct?
With kind regards,
Bas
No.
The RMS power is:
P rms = 11,2/sqrt(2) * 1,4/sqrt(2) = 15,6/2 = 7,8 Wrms
or
P rms = 8 * [1,4/sqrt(2)]^2 = 7,8 Wrms
"1.35A, which in turn implies that, into 8 ohms, the JC 1 operates in class-A up to 29W"
1,35 x 2 = 2,7A (push pull output stage)
P rms = 8 * [2,7 / sqrt(2)] ^ 2 = 29W rms 😉
The voltage will be
1,4x8= 11,2V
Is this correct?
With kind regards,
Bas
If your bias current is 700mA then the max current swing in class A will be +/- 1.4A. This is peak current. So peak power will be I^2 x R = 1.96 x 8 = 15.68W.
In audio, the peak power is not normally used. Instead, average power is used which is half the peak power for a sine wave and a resistive load. So when a product claims to be 100W into 8 ohms they mean 100W average sinewave power into an 8 ohm resistor.
So your average power = 7.84W.
Be aware that average power is often, incorrectly, referred to as RMS power. This is a term commonly used in audio parlance but is not an engineering term (mathematically, RMS power is not the same thing as average power). The basis is that the average power can be calculated by multiplying the RMS voltage by the RMS current (both being root 0.5 of their peak values - hence 0.5 of peak when multiplied together). So the prefix RMS seems to have slipped in front of power too.
Supposing the Iq current is 1.4 amp dc and is a push pull topology the current will be exactly equal for the N and P out devices if the DC Offset is zero volts.
What can be withdrawn out as call class a is this current as RMS versus an effective load
Po= (1.4*0.7)²*load, in case of 8 ohms is 7.68 watts as mention in previous answer.
Is that simple
Best regards
Williams
Is that simple
Best regards
Williams
Re: Re: Calculate class A power
I know you're wright ... but this is a well know term in audio, and if is used enough time by many people it will become "de facto", even if is incorrect from mathematical POV
Thank you Sir,
There I went wrong. I told you already I feel I miss the boat somewhere. Really stupid I never considered the RMS value. Thanks a lot now I am one illusion lessen 😀
With best regards,
Bas
roender said:
No.
The RMS power is:
or
Thank you Sir,
With best regards,
Bas
Re: Re: Re: Calculate class A power
Thank you all!
It is clear to me.
A little offtopic, but this calculation makes me realize that for example the Musical Fidelity A1 wasn't a real class A amplifier 😉
All the best,
Bas
Thank you all!
It is clear to me.
All the best,
Bas
Re: Re: Re: Re: Calculate class A power
You can call an amplifier "a real class A" only when he never fall in class B near full power ... most of them are not 😉
Sebastiaan said:Thank you all!
It is clear to me.
A little offtopic, but this calculation makes me realize that for example the Musical Fidelity wasn't a real class A amplifier 😉
All the best,
Bas
Re: Re: Re: Re: Re: Calculate class A power
Should we call it "high bias" amplifier then? 😀
With best regards,
Bas
With best regards,
Bas
Well ... yes and no 🙂
The high bias amplifier (BJT OPS only) is a wrong concept - class AB, as GM doubling will occur at the exit from class B regime and will ruin the output impedance linearity.
Correctly biased class B amplifier, as per Self definition, with low values emitter resistors can be a truly class A amplifier for low power levels, only few watts - enough for normally listening levels, and a very good class B for the rest of the scale 😉
Williams Audio said:Supposing the Iq current is 1.4 amp dc and is a push pull topology the current will be exactly equal for the N and P out devices if the DC Offset is zero volts.
Is that simple
Best regards
Williams
Dear Williams,
You multiply by 0,7 because of the 40% power loose due the inefficience of a linear amplifier?
In that case the class A power would be even less.
If you incalculate that, the formula would be
1,4*0,7=0,98
P rms= 8x [0,98/sqrt(2)]/2=3,84 watt?
With kind regards,
Bas
roender said:"1.35A, which in turn implies that, into 8 ohms, the JC 1 operates in class-A up to 29W"
Dear roender,
Sorry last question. I really want to get this so forgive me my questions.
In your example you devide the outcoming of P rms = 8 * [2,7 / sqrt(2)] by 2. Can I call that average power?
With best regards,
Bas
roender said:1/sqrt(2) = 0,71 😉
P = R * (0.71 * I)^2
Ah okay I get it now. But one confusion. I measure the RMS voltage already across Re.
With kind regards,
Bas
P = 8 * sqr[2,7 / sqrt(2)]
or
P = 8 * [2,7 / sqrt(2)]^2
Where did you see that I divided the term 8 * [2,7 / sqrt(2)] by two in the above calculations?
The general formula is:
P = R * sqr(Irms); Irms = Ip/sqrt(2)
where Ip is I peak
then P = R * sqr[ Ip / sqrt(2) ]
or
P = R * sqr(Ip * 0,71)
or
where Ip is I peak
or
With kind regards,
Bas
No, you don't. That is a DC voltage not AC!!!
- Calculate class A power
