yes i find out that if you use two separate cable for + and - set of output the sound will be much better any body tried yet it has any thing to do with aleph-x is to closed between output and the feed back? so that we have count on the capacitance of the cable or any other factor ?
Well, I've tried it with the input. I thought it sounded better than using an unshielded microphone cable to carry line level signals.
JJ
JJ
as far as the input cable goes, unshielded microphone cable seems to have a lot of crosstalk between the wires. I could see it on my 'scope, and it was slightly out of phase.....
JJ
JJ
yes
they could canser each other in aleph-x and so you won't hear then at all .............but does it make the sound better?
