c3g connections
Garbage,
I've been posting in a lot of your threads... I assure you I'm not following you around :D
Pin 1: heater
Pin 2: g3 - tie to anode
Pin 3: anode
Pin 4: g2 - tie to anode
Pin 5: cathode
Pin 6: grid
Pin 7: cathode
Pin 8: heater
(valve pins are numbered clockwise with from the key/gap from bottom view)
What are the anode-cathode and g1-cathode voltages you are measuring, and the current? Sometimes valves deviate a little from spec.
C3g
i have connected Ua = U2 = anode voltage, U3 = 0v, U1 = grid, pin 5 and 7 to cathode
Hi Garbage,
don't know whether I can be of much help, but since I am in the process of building a headphone amplifier using the C3g , I might as well post part of my original schematic. This is how the originator of the schematic, one Mr. Siemens, wired things up.
Good luck,
Oliver
Re: C3g
Pin 1: heater
Pin 3: anode
Pin 5: cathode
Pin 6: grid
Pin 7: cathode
Pin 8: heater
i realised, and i appreciate your replies, no worries mate. ;)
i only measure the anode voltage and the drd choke with current passing thru it. the voltage is 182.3 and 7.36mA with 2.7v bias.
will follow your suggestion to measure the p-k voltage and g1-k voltage.
Good luck,
Oliver
it's a great help. it is a triode strapped pentode right? i notice from another datasheet that pin2 is connected to pin 5/7 too.
Hmmm...
audiousername said:
That's odd. From ~180Va-k and ~-3Vg1-k you would be expecting about 12mA of current, almost twice what you are getting!
This is a strange one....
Don't worry about measuring the voltages, what you told me is fine :)
A strange one ? Not really . I'd put this down to device variation which is a typical of high gm valves . If it's not a new one then there also may be the possibility the valve under test is a little on the weak side
cheers
316a
Re: Hmmm...
Of course what you're saying is correct. Although 17mA/V isn't super-high, device variation is always something to consider with high transconductance valves.
Garbage,
You could always just swap the valve drawing too little current with the other channel or a spare. I can't believe I hadn't said it before. It should have been the first thing I said!
Re: Re: Hmmm...
audiousername said:
Garbage,
right, i actually wanted to do that over the weekend. i have 4 in all to play around with.
but was pretty tied up with sanding the aluminium panels for the chassis.
i did solder pin 2 to cathode as Oliver suggested, that raised current to 8.15mA, but could be due to the batteries losing some charge. i measured across the batteries and they are 2.66v.
cheers
garbage
