Bypass volume potentiometer (5 pin)
Hi
Can't get my headphones replaced in warranty during COVID lockdown so I am forced to fix the old ones.
I have a pair of old headsets that have this volume potentiometer that I would like to bypass entirely. And keep the volume full at all times.
Could anyone tell me which pins would I need to manipulate?
I have numbers the pins and shown which direction the potentiometer goes for volume increase.
Thank you
Yeah.. I thought of that. But that would require more soldering than I think I am capable of. And I am not sure the wires will actually meet each other's lengths. Those rubber block things keep them at a length from each other inside the plastic enclosure that houses this entire PCB
Is there really no way to just join 2 or more points with another wire to get the same effect?
I disconnected the green wire which goes the R-I (guessing it's Right in) and connected to the green wire (pulled from R-O - may be right out)
Did the same with L-I and L-O... the light red wire. (the dark red is mic. I think)
Would this cause any problem in the future? Or something damage to the onboard DAC/amp in my laptop?
Note : I don't use the mic on this headset
What is the wire connected to the pin 1 of the potentiometer?
