bypass ad converter in dbx
It would be better, in theory at least, to avoid a D/A - A/D cycle by using the digital connection between the Meridian and the dbx. Upgrading the A/D would call for as much if not more work than adding some form of digital input.
slr 5000 said:
adding a digital input somehow to the dbx would be ideal unfortunatly they do not have one .im hoping someone here has got around this problem before and can provide some insite as to how .
Best of luck, but don't hold your breath. The dbx is used by very few 'philes especially as the DCX is cheaper and uses more generic components (I believe dbx use their own design ADC) and so is easier to modify.
The basics are fairly straightforward but few would try it without a schematic or service manual.
