Buzzz goes the gainclone(ground loop)
Now we're talking
Hi Butcher😀,
You picked an excellent post, indeed.
Extreme_Boky said:
...Usually there are 0.01uF with 0.1uF cap in parallel between ground planes and chassis. However, earthing the chassis to mains ground is not a good idea for many reasons, especially if you have more then one unit’ chassis grounded to mains ground AND they (units) are connected together (which they are via interconnects) AND they are plugged in to separate mains outlets. The earth pins in those separate mains outlets are usually not at the same potential, which causes current to run - and it is very unclean current!!!
Extreme_Boky said:
Using mains ground is NOT a good idea.
It just doesn't mix with audio.
It brings much more problems than it solves.
Amen.:angel:
AJ Bertelson said:
How can I interupt the loop without burning the house down?
You still didn't answer (or checked) if you have more than one earthed device on your system.
Anyway, the easy way for your problem is signal (isolating) trafos.
Just for testing, you can try those cheap things used in car audio.
Insert them on the interconnects going from the pre to the power amp, or on the source.
But something strikes me now: I've seen problems with cable TV.
Do you have a video or TV set connected to CATV and to your system?
I do, but I don't have noise.
But I know a guy who had hum and had to put one of those car audio signal isolators between the video and the amp.
well after messing around with it a bit last night I noticed that it was only coming from the left channel. I played around with it for awhile and got the buzz to go away. Something else must have happened in the move but the amp works now.
Don't know why though
