Buzzing mains transformer - what helps?
I have a buzzing mains transformer on a SE amplifier. It's an old transformer. I've read up on some things to do like re-gluing laminations, dipping it in shellac and methylated spirits etc. But are there some simpler things that will lessen the buzz? For instance:
- Mount it on rubber feet
- Insert bolts into any unused holes and bolt the laminations tighter?
- ??? anything else
The transformer is a good size and doesn't get hot, so though there's no markings to identify it, it shouldn't be stressed.
1) You can make a cover for it and line it with Dynamat. Since you said it doesn't get hot the cover shouldn't cause heat issues.
2) You can decrease your line voltage with a variac or AC regenerator/regulator. Lower line voltage usually means less buzz.
3) You can removed it and have it vacuum impregnated at a transformer or electric motor repair shop.
Andy,
Does the transformer have an end bell(s)? Try removing it/them.
Does it buzz with no load? Can you feel the core buzzing?
Yes rubber mount is okay. Soft grommets work if you can enlarge the mounting holes and felt pads also work as long as you do not over compress them. Either case, make sure you ground the transformer frame back to the chassis.
Andy,
No end bells. Doesn't buzz with no load sitting on the bench.
On load I feel some very faint vibrations, but not anything substantial.
I have another identical transformer, but with end bells. I'm about to try that out. If that works I have a working PSU and I can do experiments on the buzzing one later, incorporating all the ideas in this thread.
The buzz is caused by hysteresis making something loose vibrate.
Can be an air gap in the laminations, dried out potting compound, whatever.
I simply run them on load, and varnish the coils and laminations.
On load means it is warm to hot, so the varnish flows better, and the vibration makes it find its way to the right place.
If possible. loosen slightly the bolts holding it together, tighten after the varnish has gone in.
Varnish takes a long time to set, and has a long pot life compared to other potting compounds, will not dry up if left open for an hour or two.
Just soak it in varnish, connect on load, for about ten minutes.
Take it out, let it dry overnight in a well ventilated area.
The excess varnish can be stored after adding a little (compatible) thinner.
Vacuum impregnating again to an existing unit...no experience.
