buz 103 for punch amplifier
hello everybody🙂 "ps:sorry for my bad english i'm french😀 "
i have an amplifier rockford punch 200.4 that i have bought 50 euro.
but it has a buz103 out of order in the power supply but it works.
is it possible that i replace it by a irfz44n mosfet?
thanks for your help
by++🙂
What are the numbers on the top of the gate resistors?
Do you have a 10 amp fuse in the B+ supply line?
With only the remote and ground connected (no B+), what is the DC voltage on the gate terminal of each of the PS FETs (black meter lead on the ground terminal of the amp)?
You should email Rockford tech support to get a schematic for the amp.
hi everybody
the irfz44n are not good for this power supply😱
maybe it's cause of "RDS on" is not the same value, the irfz44n has a "RDS on" 17.5mohms and the buz103 a "RDS on" 0.04ohms
I have replaced the irfz44n by mosfet Nchanel fqp50n06
with "RDS on" 0.022 ohms and the noise in the power supply has gone.
the rockford fosgate work🙂
can you confirm me please if it is the "RDs on "value that do the noise in the power supply?
thanks😎
The RDSon should not be a problem. I use IRF3205s as replacements in Rockford amps. They have an RDSon of 0.008 ohms (8 milliohms) and I have no problems with them. I've used IRFZ44Ns in Rockford amplifiers with no problems.
Without being able to hear the noise, it's difficult to know what was causing it. In some power supplies, the transformer will make noise and simply touching the windings will quiet it. It's possible that you may have moved the windings slightly while working on the amp and that's why you no longer have the noise.
thanks perry🙂
i have a question, i don't know what is your job but i think you repair amp for caraudio?
so i would like to know what is the type of studies for doing this job and repairing amplifier in caraudio?
because i would like to do this
thanks for your help🙂 🙂
