Buying an LCD monitor...
A 6" monitor will have a smaller projected image, meaning you can move the projector further back than with a bigger monitor(assuming you would use the same lens) Also, a six inch will have more even lighting, but because of the fact that you're using an OHP, not all the light will be directed toward a 6" monitor (the 6" won't take up the whole display area of the OHP), and you will get fewer lumens (or lux, or whatnot...not quite sure what the correct term is here 🙂 ). Also, a 13" panel will likely have higher resolution, better contrast, and whatnot.
