Buying a panel from another region
I was considering an lcd panel, but it is from the UK. My question is there any changes that need to be made on maybe a refresh rate of the lcd panel (if there is one), or some other type of change that needs to be made before it can be used in my NTSC setup? Or will it just not work with an NTSC setup?
Because projector panels are difficult to find in Belgium I bought
an infocus panelbook from the usa.In Belgium the televisionstandard is pal never the less the panel worked fine.
The main diffirence between Europe and the usa seems to be the
powersuply- in europe it is 220 v in usa 110 v.This is easy to fix
with the use of a adaptor.
Hope this helps.
