Hi.
My fathers speaker suddenly did not work so i kinda look at it.
I found out that there is one burned amp IC.
There no same on local/elec. stores here.
So can i replace the burned
NS4160
With
LTK5128?
Or is there any other IC i can replace to it?
Thanks..
NS4160
With
LTK5128?
Thanks..
It has the wrong pinout so no it will not fit.
I would order the correct one.
【NS4160 纳芯威】Buy Now【NS4161】【NS4162】【Price】【цена】Electronic Components Stock in USA 2020【Datasheet】【PDF】
Apparently you can get the oiginal one for 18 cents or ten for $1.50 on AliExpress.
I´d get the proper one.
Thanks for checking the pinout. I'll probably buy the same ones. Thanks
Thanks for the info.😀
