Bus-powered PCM2707 configuration using SPI
Hello,
My problem is about understanding how to configure a PCM2707 thru SPI when the device is in bus-powered configuration. I don't really understand the diagrams on the datasheet (SERIAL PROGRAMMING INTERFACE (PCM2705/7)) pages 23 on.
Is it eventually possible to configure the device using a PIC18, just after the user plugs the USB connector ? Many thanks.
Best regards.
