Burson Audio Funk left channel not working
Just compare the resistence of the right channel with the one on the left channel. This is a quick test I do before removing the cover, to see if there is something obviously wrong at the output. It is not a comprehensive test by any means. The faint sound you hear may be related to a intermittent fault. Bring down the volume control at normal level and tap lightly over the circuit board and the output relay with a plastic/wooden tools, just to see if there is any sensitive spot. Do not use your good speakers because connecting them to a faulty amplifier may be risky. You already unknowingly took some risks by turning the volume at 100%. I've seen faulty potentiometers with intermittent broken internal connections.
I'll check that.
By the way, I'm gonna explain how the left channel died.
First it didn't work but after I moved the rca (in both sides sound card and amp) it worked, I thought could be the cable or I wasn't connecting the cables firmly (that was my thought), then when I was about to add the cables for the subwoofer, it finally died, no more audio on the left channel.
A common issue on some RCA jacks is a deformation of the inner contact that should touch the central pin. I've replaced several jacks with this issue, and also found the issue on brand new connectors imported from China. It is very easy to check if you have this issue. Disconnect your RCA cable from the source and measure the resistence between the ground and the central pin on the faulty channel. If the bad contact is confirmed, try a RCA cable with expansion type connectors.
You need to rule out upstream and RCA connection issues.
Try this:
Connect old throw away speakers.
Connect right RCA. Play music. Ensure sound is good.
Disconnect right RCA and plug it into the Funk left RCA in. Play around with the RCA connection. Slide it in slowly and out slowly. Rotate it. Wiggle a bit. When or if you get sound note what you did. Try and reproduce it. Try different RCA cables.
If you followed the previous suggestions and the amplifier is still defective, I believe that a easy fix is unlikely and the attempted repair will require tampering with the device. I would contact the seller and/or manufacturer and evaluate the options. They may be better than you think.
Try this:
I did that already, different cables, different dacs, switching from headphones/speakers.
You are right, probably is the potentiometer that is broken or something else,
I already contacted Burson, $300 lost for testing a unit, what a shame.
You said both amps (main and head) are only 1 side working meaning that the signal is interrupted in the common part from input to the buffer after the volume control. This is also where the opamps are working.
I guess one of the opamps might be damaged or not well inserted or has loosened from the base because of vibrations during transport.
So pull the amp of the dead channel out and substitute it with a NE5532 or similar and check all traces which are accessible.
I firmly pushed both op amps, I replaced the one close to the RCA inputs with one that I know was working properly (that one came with my Sound Blaster AE-9) and I got the same behavior.
I didn't touch the other OP amp because I think is intended for the headphones.
Off topic, anyone knows if Rega io amp is any good?
You can operate the amp without the opamp, nothing can be damaged, to see which channel is amplified by it. There are no schematics available so we do not know what the opamps are doing.
A good guess of yours is the volume pot try to touch the slider connections with a needle or your finger and see if some hum is heard.
The second opamp is probably not from the phone amp because it says discrete semis.
I received the second unit, what a shame, similar problem with the left channel.
This time the left channel works but sometimes (when is cold) either makes pops, white noise then pops again, or gets silent.
The first 24 hours it did lots of pops, then white noise, then pops again.
Today, on my second warm up, it worked for a few seconds, then got muted for about 30 seconds, then the sound came.
When is cold the left channel doesn't seems to work properly, when is warm (about 4 minutes) then the issues are gone.
This time I turned off the amp for about 30 minutes. After turning on, I only got a few pops in the left channel.
So I think if it gets really cool, then more issues appear, Kind of like has to be warm in order to work properly.
After talking with burson sales department, they told the to switch the op amps, I swaped the V6 with the IC ones and no more issues.
So this time the issue was the OP AMP, I'm still doing more test but for now that seems to be the problem.
