Burning Amp BA-3
Output stage for BBA3
I'm hammering up a BBA3 and I just realized that I do not have an output stage to mate it with😛
Really just an excuse for finding additional projects😀
Any suggestion anyone? I don't need much power and I don't think I have heat sinks for 300W dissipation.
Nic
Nic
I think the 300W refers to the full six pairs of fets i.e., two output boards per channel. More manageable if you just use one output board per channel.
Chris
Chris
A single mosfet pair would mean two pairs or 4 fets per channel for a balanced setup. If you ran two mosfet pairs, that would be 8 per channel and you would need even more dissipation capability than standard BA output.
Standard BA-3 has 3 pairs or six fets per channel. If you look at the schematic for BA-3b, you now have to double that in order to have a complete amp if using standard output stage. Think of BA-3B as a pre-amp and the needed BA output as an F4 running as a mono-block instead of stereo output. Go back and read listing of BA-3B info and look at the output power compared to standard BA amp. That did not come from just different FE. It is a function of the FE and the doubling of the output transistors.
hi Backbones,
the problem is - the Mac software is on a desktop PC (hackintosh) and I put the amps besides it,
when I have in November the software on my laptop (windows software) i can measure and hear in my living room with the speakers, so I have to wait if I prefer more or less k2......
I might beat you to it by just twiddling P3 one way and then the other--adjusting everything else along the way--and having a listen.
Now I've soldered everything in place can I measure the R value on P3 for different positions (thinks to himself); I'll go down to the garage and see.
Chris
hit me please, hit me, hit me....wasn´t there a song like this 30 years ago?
why are you going to the garage? and was "measuring the R value of R3" a question?
I am very eager to hear if you can hear a difference!!!!!!!!!!!!
good luck!
