As a novice at my first BA,
I would like to thank first of all Fritz Heiler of Fritz Speakes,
my neighbour at booth that lent me a couple of his precious
loudspeakers allowing me to make a real demo
of my Switchinglow Project.
Then many many thanks to Charlie Laub
for all his hints about the event.
Thanks a lot also to Variac
for had found time to see my Project,
and to Jason Donald
for his great job with this inestimable forum !
Thanks to everybody picked up my leaflet and
thanks to the lucky guys
that had time to stop at my unofficial talk.
Sorry for the others, but I prepared the slide show at the last minute,
so had no chance to add it at the BA official schedule.
Anyway, I'll soon attach here the slides.
Thank you again to everybody !
and to Jason Donald
About 220..230KHz with the basic free run analog input PWM modulator provided with the kit.
192KHz or other standard sample frequencies locked to the PC player with the XMOS XS1 based full digital USB PWM modulator.
This week end I'm going to show the system at the Gran Gala' dell'Alta Fedelta' in Milan, here in Italy.
Then probably I will start a new threat on the Class D section of the forum...or on the Tubes section.... just to move any technical Q&A in a more suitable place.
I've started this morning a new therad here
http://www.diyaudio.com/forums/clas...witching-power-devices-h-bridge-circuits.html
just in case there will some more tech discussions or somebody else
will be interested.
And thank you so much for the pictures !
will be interested.
I've also posted here
http://www.diyaudio.com/forums/tubes-valves/300368-switchinglow-project.html
in the Amplifiers Tubes/ Valves section
as the Switchinglow is also a real tube amp,
as the tubes are used to feed electric power from the supply to the load...
Who knows if in the future there will be a further forum section
for Amplifiers-Tubes-Class-D
just to keep them apart from Amplifiers-Tube-Linear
or apart from Amplifiers-Class-D-Solid State.....
- Member Areas
- Clubs & Events
- Burning Amp 2016 debriefing
