Burn In speakercable
Call to arms.
jleaman, if you will do the cables, please add a few words about them in the wiki. See link in my signature.
Somebody else should write a few words about the burn-in procedure.
IMHO if the wiki is kept simple it's good. Doesn't have to be fancy, just straight descriptions of what's needed.
You have a 50/50 chance of a correct guess in ANY A/B type test.
That is why at least 10 correct picks in a row is generally accepted as placing the statistical probability of guessing below reasonable doubt. It's been done this way for quite some time now.
There is a reason why the methods of blind and double blind tests have been well established. It precisely to avoid all the bicker and discussion traded over the last 15 pages here. It's all been argued and hashed to death many times before. Blind, DBT, and ABX testing methods exist as they are for a reason. - To avoid all this mess.
Did you happen to miss the part that the first trial will involve TEN cables?
How often could you flip a coin and get three or four heads in a row? Being fair and objective isn't as easy as you make it seem.
Now about your preference of a one shot test of two cables. Even a positive result can be refuted by those who are against. A sample of one is not significant.
That is why an A/B test is randomized between each round, and carried out until 10 correct answers within 16 tries (or better) occurs.
Several people here need to Google more about this. It's all been debated and done thousands of times before. It's standard, cut and dried because of protracted debates about odds and probabilities such as this.
Wow...
There's a word that comes to mind that describes these latest developments: Absurd.
I feel ridiculous just reading it.
Oh look, a wiki too.
X2.
Do it right, or don't do it.
SY. With part 2 of the test will Andre get 10 pairs of which 5 will be burnt in and 5 not? I mean will he know that there is 5 of each?
If the cables are IDENTICAL except for half burned in and half not, how do we know he doesn't just switch the labels around to his benefit?
Why? I find it a lot more ridiculous to read and participate in a 70-page debate about this topic without moving one finger to prove either side.
If you knew how little I care if the result is either or. But that's not the point. I guarantee you this: if we manage to get the test done properly, no matter what the result will be, years later people will still read about the test, and not the 70 pages of worthless chatter. That, to me, is a real winner.
Good point, I had to think about this for a bit when I first wrote just two classes.
To be honest I don't know, just thought about covering all possibilities in stage 2 of the test. Given a number of cables and two classes, new and burned-in, it is conceivable that some of the cables would be perceived as surely new, others as surely burned-in, but others as neither.
Perhaps Andre can testify if he ever had this experience, where he just couldn't tell whether a cable was new or burned-in? Anybody else?
John, what would you say? Just new and burned? Or also not sure?
