No, the inductance you show is about 100 times greater than the original (compare 330µHy and 4.7µHy in the other).
Transformer appears to be capable of a try.
No problem with the largest value of the coil
I chose to increase it is based on people who have done the mod on the DENON 2900 SMPS
This is the coil in Login regulators and filter noise function only
The problem is to find a small coil diameter 330UH have and still with 3A
I understand why Dannon fabricate such a bad coil filtering
Not because of the ability to filter. only because coil with 330UH and high amps ar expensive and big
