Building my first FR project....
I just got my Fostex FE126E speakers yesterday. I have started building the recommended hybrid horn/br enclosure and everything is looking good so far. My question is about mounting the driver. Do I need to flush mount or surface mount the drver? I have searched the forums and haven't found much information on a preference.
Any comments would be appreciated.
Tim
Ok another quick question. I have all the pieces cut for the recommended enclosure. I have the sides glued up and am ready to start with the internal pieces. Any tips on how to secure the pieces while the glue dries? I am a novice woodworker and having some issues trying to clamp them on the angle.
Any tips would be appreciated..
Tim
Thanks for the tips. I have been using a stack of 5 pound weigths to hold the pieces down, its just pretty slow going. All the other speakers I have built (this is my first BLH however) have been glued and screwed. But this small 1/2" MDF box is just getting glue and no screws. I may try some finish nails though...
Tim
wood dowels
Another option is 1/4" wood dowels usually 1" in length with glue. Just drill a hole for them 1/2" deep in the internal angle piece, then mark the spot on the side where the dowel touches and drill a corresponding hole in the side piece. This will keep the piece in alignment and provide exceptional strength when glued. All you need is a drill. And you can cut the dowel shorter if needed depending on the thickness of the wood. Just be careful not to drill your hole tto deep and punch through the side piece!
Re: wood dowels
Have a browse online for "biscuits" - they are like dowels but wafer shaped and thus permit a little lateral movement for alignment. I'm a newbi and found them so easy to use with impressive results. I went for a dedicated Dewalt biscuit joiner but you can buy adapters for angle grinders and routers if the cash outlay is an issue. Have a nosey on eBay... Good luck!
Dowels, and Biscuits, and Screws, Oh MY!
I have been pouring over tool and woodworking material and even went to a used bookstore and purchased a book on making a router your best friend when I could not for the life of me figure out how to loosen the collet. (I left the expensive new books at Barnes and Nobles and have decided that there is not much new in the world of routers.)
I love all this joinery stuff but after a 20 year sabbatical from speaker building I am finding that masking tape and a couple corner clamps has eclipsed all my interest and plans to use pipe clamps, dowels and dado's. There is so little time for this stuff that my aspirations for instant journeyman status in the shop has taken a backseat to pragmatics. I have found that square cut wood lines up quite nicely with the corner clamps and for the span between, good old masking tape does great. Though, I am impressed with the idea of using old car batteries.
This Titebond III glue is fierce and loyal. I have gone back later and drilled/countersink a few holes for the MDF screws that I have put in for good measure should the boxes get pushed or moved much. I have discovered a whole new genre of drill bits and counter sink tools, some that let you come back and use little wood plugs to cover the screw head.
There are many ways to skin a cat and flush mount a speaker. I went in to the woodworking shop in town ready to implement the thoughtful suggestions I had received about using a bigger and a smaller router bit and got talked into buying a brass inlay router kit. It is simplicity itself with a bearing that guides the router around the speaker frame and then swapped out to make a template. It cost about the same as the two router bits but is quite a good hack.
But blessed are the biscuit makers and dowel users. Hats off to ya.
