Whenever a Member asks about using an SMPS for a Power Amplifier, I ask them to consider:
Where does the speaker get it's current from?
The tiny output capacitors that are part of the SMPS emi filter cannot supply the currents demands of a high SPL bass speaker.
I've got a question. I started filling in the PSU portion on the boards and realized I don't have enough of the BYC32E's. I have some MUR's but then I noticed that the pin spacing doesn't fit either of them. Was there something else originally planned for that spot?
Thanks, Terry
Thanks, Terry
Thanks Patrick but I can get more from Mouser. I was more curious as to why the pin spacing is so wide.
Thanks, Terry
Thanks, Terry
I think it has to do with the footprint used in the software.Hugh has made the layout and he uses Protel
Terry same findings as me,I think it has to do with the PSU caps of the SMPS 4x 1500µF just isn't enough as special if you run two channel with one SMPS.I think to get the bass right with a SMPS you need one with more wattage cause you get more capacitance for the output caps.
A higher wattage SMPS might work slightly better, but after reading some posts by the designer of the SMPS series by Connexelectronic, it seems we can indeed use any size capacitors after the SMPS we want, we only have to take care to limit the in-rush current. The over-current protection is likely to kick in with any wattage SMPS if the cap bank is large enough.
I'm building mine with a SMPS300RE and if i find the bass lacking i will definitely look into bigger caps & in-rush current limiter. Just need to find a solution which ideally doesn't involve a mechanical relay and doesn't cost too much.
On a side note i decided to try using a BF862 for T1. Anyone else besides me and aspiringv trying that?
A current limiter between the regulator and the cap bank will need to be bypassed after start up has been achieved.
Otherwise the regulator function is crippled.
The other Threads discussing Power mosFETs as switches have a non mechanical solution.
I would be tempted to go with Power NTC Thermistor.
It is precisely this duty they have been designed for.
If your supply ramps to 50Vdc quickly, then initially when the capacitor bank is discharged the full voltage is available to charge the caps.
If you know what output current the PSU will tolerate as start up current, then simply find the resistance from: Vdc / Imax at start up.
Then calculate, or estimate, the time required to substantially charge the cap bank from RC and tapering off of the charge current.
Finally bypass the resistance to bring the PSU fully on line.
This should all be inside the SMPS desinged for audio power amplifier duty.
If it's not then the SMPS is not suitable for audio power amplifier duty.
I recall a discussion on modifications required to allow one of these SMPS to start up when output bias was set highish. That again points to a poorly designed SMPS for audio power amplifier duty.
I get the feeling that the two major proponents of the audio SMPS on this Forum do not understand the transient requirements of Audio Power Amplifiers.
from this thread.Cristi said:soft-start time is fixed and optimized during design. I chose the most suitable time for each SMPS. it can be changed by replacing one small capacitor but is not recommended unless there is no other way to charge a huge amount of capacitance.
Cristi is the designer of the SMPS300RE, elsewhere in that thread he states that the soft-start time constant is chosen to be just enough to charge the on-board capacitors. He says it's 100-200ms now. So with a total capacitance (SMPS+Fetzilla) roughly equal to the original design capacitance of the Fetzilla, assuming a linear ramp-up of voltage, what time constant should we shoot for?
(I'm looking at you, AndrewT)
All the best,
Kris
With a max current of 4A * 36V(preumably higher during ramp-up), what you reckon the ballpark time constant is? Would 1000ms be enough?
I realise now that AndrewT's comment likely refers to the discussion about adding a Power NTC or a regular resistor to limit in-rush current, i'm still not convinced it has come to that, there may still be a way to tweak the SMPS300RE in a way which will allow it's built in ramp-up to last a bit longer, but for aspiringv's SMPS it may prove necessary. I did find this from the SMPS300RE page:
It's not entirely clear if he means that the OC protection kicks in at 520 Watts, i.e 6.8 Amps per rail(260W/38V), or 390 Watts(i.e 5.1 Amps per rail) but i guess it's something that can be figured out if need be.
Aspiringv, i found this page:
Charging a Capacitor
It could help with figuring out how big a resistor is needed. I put in values of 9701uF and 38V, and using a 20 ohm resistor appears to limit the current to 1.9 Amps and still gives us a sub-200 ms charge time(ideally, my guess is it will take slightly longer to charge).
Now all we need is a way to calculate the charge times with a rising voltage, but ideally we need more details, but for argument's sake let's assume a linear ramp-on over 200ms. With an SMPS300RE "Imax" of 6.8/5.1 Amps(per rail) we should be able to calculate a maximum cap size that is safe. This feels like an integral equation, let the math wizardry begin!
The SMPS300R features over-current protection which limit the output current at about 130% of the maximum peak power, about 400W.
Another SMPS shutdown when trying to start with a 600mA output bias setting (600mA Ib).
They discovered that by reducing the bias setting to around 300mA that the SMPS would start up and fully power the amplifier ready for use.
I don't know whether they have a method that allows the original 600mA Ib to start up.
- Building FETZILLA - Questions and Answers
