well next question... I have somewhat the parts list finished now I just would like to know, where do you buy the C9 - 0033nF? Im not sure what manufacturer to buy...
I found this one
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=BC1611-ND
what do you think?
I found this one
what do you think?
PS the R9+10 I would like to buy this one
286-2.2K-RC Xicon Metal Oxide Resistors
its a 5w but that should not be a prolem
Hi Daniel,
not only that he (jackinnj) can, he will (see photo below)... 😉
Second photo: suds PCBs & heatsinks 40x165x400mm (from other supplier)
Hi, does your heatsinks work well with Sud's pcb??
For me with Sud's pcb is obligatory use a pcb with circle red part
I mentioned the same thing on post 29.
Imagios reply:
Well I will need a L profile to mount to the pcb and the profile to the headsink
...yes but a L profile mount on the heatsink have good heat transfer ??
Hi gioz,Hi, does your heatsinks work well with Sud's pcb??
I didn't finished yet, but my solution you can see below.
See no problems.
Hi gioz,
See no problems.
& for fun!
Imagios reply:
My L profile is 310 mm long and 50 mm wide... 😉
I received the pcb yesterday ;-)
I have the parts from line (from techdiy ...but the trimmers are not good for this pcb) and a 500VA transformer.
I don't have the parts (resistors and capacitor) for powersupply and the thermistor cl60.
I have almost all parts... butI received the pcb yesterday ;-)
For capacitors see:
http://www.diyaudio.com/forums/vend...68000uf-kendeil-caps-sale-16.html#post2480303
... and the rest from umut.
Hi, I have some problems...
I bought from TECH DIY Tech DIY Company Store the F3kit but some component (capacitor and attenuator) don't fit in the Sud pcb.
Anyone have the same problems?
Hi gioz!Hi, I have some problems...
I've checked all components (also from Tech Diy) for my F3 and, yes, you're right
Also the attenuators don't fit...
The rest (resistors, transistors,...) is correct.
What to do? No other way as to replace 18 capacitors and attenuators (2). OK, it's not big money but...
And you?
At the moment it's not to our...
Hi gioz!
I've checked all components (also from Tech Diy) for my F3 and, yes, you're rightThe worst is with capacitors, only one (from 10) fits to the pcb. Have to say suds pcbs are from this view correct - consistent with earlier P. Daniels BOM for F3 amp.
And you?
& for fun... (hope it will be... someday 😉 )
I'm discouraged 🙁 ...I'm thinking of selling all
Oh, no gioz! Don't do it!I'm discouraged 🙁 ...I'm thinking of selling all
(But, if you do so, I'm interested)
& for fun !
Full kit, some photo
www.audiofaidate.org • Leggi argomento - Kit FirstWatt F3 (tutto il necessario)
- Building F3 - Clone Suds version
