With the current version of Miero's distribution there is a web service already running
Code:
http://BBB_IP_ADDRESS_OR_HOSTENAME:8080
Yes, I was aware of the BBB's inbuilt webserver, but you didn't mention exactly what that webserver application is. No wonder, it's very difficult to find information about it. Google tells me it's a basic socket server, possibly javascript, or possibly a python script.
Can it be adapted/modified to serve MPD album art? Very hard to tell.
I still think it makes sense to install lighttpd to serve MPD album art. This is known to work well with the MPDroid Android client.
If anyone cares to run this command on their BBB -
we could probably determine what the webserver is.
Code:
systemctl list-units
The cape is actually not design to stand alone in this regard - the Cronus would come into play. 🙂
On the Cronus there is a B3 header for direct connection to B3 (up to 8 channels I2S) - there is also a header and uFLs for connection to B3SE (stereo).
Actually you really would not want to route multiple DACs (say for dual mono) with uFLs on the data lines without some serious thought. Because you also have to route the bit clock and word clock as well. That could get all kinds of messy.
I am looking for a proper solution to route signals from a 1.: teleporter (i2s to extern CD-pro transport) and 2.: waveIO or amanero via OTTO-II to a dual mono buffalo IIIse. I could connect the teleporter with short cable to one input of the OTTO-II and the waveIO with short (5 cm) uFL Cable to the other input. But the OTTO-II has only one set of uFL connectors for output. So far I have nor found a solution to connect right and left buffalo with uFL to one set of uFL connectors on OTTO-II. Would it be a viable way to use some sort of small "interconnect" Pcb with 1 set uFL on input side and slit the signals to 2 set uFL on output side. from there I could use again short uFL (5 cm) cable to the two buffalo.
The same problem goes for the BBB. As i do not want to build it in my dual mono dad enclosure. I would like to build it a external enclosure and connect it via teleporter to the dac. with teleport i could use 2 data lines, word clock and bit clock. but again i would have to split these 4 lines to both dacs (preferably with uFL).
I tried already "some serious thoughts" but got no result 🙁
What would be the best way to connect the extern BBB with capes to the dac. and what would be the best way to connect the signals internaly to a dual mono buffalo IIIse?
thank you for helping
My approach would be to use two transmitting teleporters out of the OTTO-II (transmitting identical signals) and two receivers - one to each mono DAC. Probably a better question for the Teleporter thread though. 🙂
I hope to have some ballpark numbers ready in the next couple days.
Any chance of an estimate, Brian?
Working on it. we made some tweaks to the boards and I am waiting a final quote on some custom XOs.
Thanks Brian. I thought it might have slipped your mind, but you seem to be on the case.Working on it. we made some tweaks to the boards and I am waiting a final quote on some custom XOs.
Real world testing prompted us to make a few fundamental changes to the way the Rhea and Cronus work. Miero has been fantastic giving great feedback on the beta boards. The beta boards worked extremely well - but the final version will be even better thanks to this early testing.
Cheers!
Russ
Cheers!
Russ
Hi Russ,Real world testing prompted us to make a few fundamental changes to the way the Rhea and Cronus work. Miero has been fantastic giving great feedback on the beta boards. The beta boards worked extremely well - but the final version will be even better thanks to this early testing.
Cheers!
Russ
Have been watching from the sideline with great interest over the year(s). Even-more-so with these fundamental changes? Hopefully, they are not too greatly impacting the availability milestone?
May be a few hints on the possible improvements based on the current beta testing?
Regards,
Chanh
So, both good and 'bad' news 😀.Real world testing prompted us to make a few fundamental changes to the way the Rhea and Cronus work. Miero has been fantastic giving great feedback on the beta boards. The beta boards worked extremely well - but the final version will be even better thanks to this early testing.
Cheers!
Russ
Only good news as I see it - we will be opening orders soon. Beta boards were meant to prove the concepts (Hermes-Rhea-Cronus) - the production boards will bring them to fruition. 🙂 I finished up the designs yesterday. We just have to work out logistics and costs are before we open up orders.
Cheers!
Russ
Cheers!
Russ
Excellent! That is indeed very good news. It's has been quite a journey 🙂Only good news as I see it - we will be opening orders soon. Beta boards were meant to prove the concepts (Hermes-Rhea-Cronus) - the production boards will bring them to fruition. 🙂 I finished up the designs yesterday. We just have to work out logistics and costs are before we open up orders.
Cheers!
Russ
One cool little tidbit for beta testing - in doing this testing I found that as long as your source clock *is* the master clock to the B3/B3SE you can go up to 384Khz with the ~50Mhz family of clocks. 🙂 It works fantastically. No need to go with the ~100Mhz clocks.
I see this project focuses on the BBB however could this be ported over to work on the pcduino3, after all it has a few improvements.
Built-in WIFI, sata, 1gb of ram, dual core a7 cortex.
I assume that this is good news from a cost point-of-view?
- More Vendors...
- Twisted Pear
- Building an open embedded audio applicance.
