I have a question. I want to build an amplifier around 200whats a channel, 2 channels. Any schematics, or designs you can recommend? not too overly complicated.
THere is really a lot of designs you could find by simply searching the treads...try it you'll see
Joined 2002
I'm in the process of making my first DIY amp - it's a dual mono P3A variant, so in theory should be capable of 200W per channel easily.
Check out Rod's Site for some more on the amp (it's highly regarded by everyone I've spoken to about it on this forum).
http://sound.westhost.com/project3a.htm
P3a is really easy to build and sounds fine. I am building 4 modified P3a's for my watercooled 6 channel amp. The other channels are Leach amps. I have built them and they sound great. Leach amp might be the way to go because there are PCB layouts available if you want to make your own boards without designing a layout. Etched and drilled boards for P3a or the Leach amp are available too though.
Good luck!😀
Good luck!😀
- Building an amplifier
