Last few questions,
1. You guys said 160VA-250VA(watt) per channel will be enough "save". Does it apply to the transformer before bridge or after?
As an example,
1. a 250VA Transformer 115V Primary, 25V/25V Secondary, and 10A. Bridge: *1.414. Finally = (25*1.414)V*10A = 353.5
Or
2. a 250VA PSU, Transformer: Pri: 115V, Sec: 17.7V/17.7V, and 10A, Bridge: *1.414. Finally = (17.7*1.414)V*10A = 249.4VA?
Which one is right?
2. Does Secondary Voltage important to match the datasheet's graph? Or I just need to get enough VA(watt) rating?
Ex:
Speaker: 10 Ohm, 35W. Target Power supply 20V Power rail 26-
28V each.
Transformer A: Pri 115V, Sec 20V/20V, 12.5A
Bridge: *1.414 = (20*1.414)V12.5A = 353.5VA Per Channel
Or
Transformer B: Pri 115V, Sec 12V/12V, 20.8A
Bridge: *1.414 = (12*1.414)V20.8A = 352.9VA Per Channel
3: If I am going to have some high current transformer such as above. Can a 3.15A fuse handle it, like Nuuk's site suggested? How is fuse work?
My guess:
If it break when there is more than 3.15A go through it, then I should use higher rating fuse for those high current transformer, right?
All those through are my guessing only. Plz correct me, and my math. Feel Free to comment.
As an example,
Or
Which one is right?
Ex:
28V each.
Or
My guess:
