So I was thinking about building a line array cabinet of sorts kinda like the RCF line array tops but using some eminence Delta 10A's that I already have and I was thinking about buying some eminence LA-WG14 array horns with their drivers. Has anyone tried those horns?
Any other non expensive array horns you could recommend?
I picked up a pair of eminence horns to work with my drivers. The horns are like 100*40. I will post pics as I build
I built a lil mini line array My bluetooth speaker project
but no I didn't use those horns, they're probably bigger than my speaker cab.
Can't wait to see yours !!!
Interesting. You put very much effort into the construction, seems to be very nice craftmanship, congratulations! In an acoustical sense it's not a line array though but if it does what you're expecting from it, that does ofcourse not matter. I'd really like to see some measurements.
