Build Thread: LME49810 + 8 Pairs ThermalTrack
Gave up on making my own power supply boards and instead i went with these. 4 of them should do running 2 for each toroid. Also ordered 8 x 1500uF 100V Chemi-Con KMH caps and have 2 more dozen .1uF 400V film caps comming as well. Now just gotta find some suitable T0220 Rectifiers, which shouldn't be hard. Probably looking at 20-30A units and call it quits for the power supply.
Just noticed i posted the wrong link...
Here is the proper link to the PCB 🙂
Heavy Duty CRC Power supply kit
Power Supply Boards showed up today and Started "stuffin" them right away with parts i had on hand 😀
Here's the end result...
Still missing :
R1 - R 10 : 1 ohm 3W 5% - 32 pieces
R11,R12 : 2.2K 3w 5% - 8 pieces
D1 - D4 : MUR2020 - 16 pieces
D5 : 1N4007 - 0 Pcs
C10 : 10uF 63V – 4 Pcs
R20 : 3.3K 1/2W if the AC input is 24Vx2
LED : 3mm green or red LED
C7, C8 : 0.1uF 100V - 0 pcs
C1 – C6 : 4700uF – 15000uF 50V or 63V – 0 pcs
Seems like I have a trip to make to the EPS and do some shopping 🙂
Been very busy at work and had no time to work on it so it got put on the back burner 🙁
HOWEVER...
At work they were upgrading some of our servers and seen this !!!
As you can see these bad boys are rated for a Maximum of 51.7V and 57A !!!!
At a mere $12 its a bargain !!! Has anyone tried to experiment with these ???
Still missing :
D5 : 1N4007 - 0 Pcs
sorry guys got really busy with work, and i forgotten about this site...
I received the following items from LEPS
R1-R10 -> 40 Pcs Dale 1 Ohm 5% 3.75mH
R11-R12 -> 10 Pcs Dale 2.2K 5% 3.75mH
D1-D4 -> 16 Pcs MUR2040
Still have to order the torroids from antek and figgure out a case
This thread is way overdue for an Update !
I will be ordering a case in the next couple of days from Par Metal along with heat sinks.
Case is a Custom 12 Series chassis ( 17 x 8.75 x 15 ) with a 8 x 4 x 14.95 C channel that runs down the center of the amp housing the soft start and torroids.
Heat sinks are 2 x HS-0712-b ans they are going into a 1.5" C channel and will be setup as forced air units.
Fans ( 1 x 80mm on each side ) will be PWM controlled by a temp probe in the middle of the heat sink that will keep them at 20% untill it reaches 28C where the controller will be ramping the speed up gradually as temperature increases.
Transformers should be here Tuesday and they are 2 1KVA Antek AN-10440 I spoke of earlier...
In theory...
40VAC x 1.4 = 56VDC @ 12.5A per rail
I should see 112VDC rail-rail @ 12.5A
I'm still on the fence about running this as a true dual Mono Blocks with independent power supply's or tie the supplies together for even higher current delivery.
